by Scott Strampe
This is a testament to my laziness. I had been planning for years to build a Myford-style, upside-down, behind the part cut-off tool. I never got around to it.
I recently was faced with a job that required parting off piece after piece. I could manage an occasional cut-off with a conventional tool, but doing a deep cut on a production basis was out of the question.
The light bulb came on in that dusty area between my ears. Why not flip the tool over in my Aloris-style toolholder and run the lathe in reverse?
I tried it, using a block of aluminum to raise the tool to centerline. It works like a champ!
Three caveats! 1) Most obvious, your lathe must reverse. 2) Do not attempt unless you have an Aloris-style WEDGING toolpost (no piston-style). 3) Your chuck must not be a thread-on type or the tool will unscrew the chuck from the spindle nose and possibly hurt you or your machine very badly.
In case you don’t recognize it, I have a 14-1/2” South Bend with a threaded spindle. I made a clamping collar to secure the chuck, originally so I could reverse the spindle for rapid braking.
I hope this serves you well.
Thanks Scott, your subscription has been extended by an issue!
Please do us a tremendous favor and forward this e-mail to your machining friends!
